PUBLISHCOLLATE system variable
Collate published sheets
Combines published sheets with equal output configurations into single multi-page plot job.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Process the sheet set in multiple steps (one sheet at a time) to generate a PLT file for each sheet. When plotting, the sheet plotting sequence can be interrupted by other plot jobs. On (1): Process the sheet set in one step to generate one multi-sheet PLT file. When plotting, the sheet plotting sequence cannot be interrupted by other plot jobs. |
Note: A plot driver that supports the multi-sheet plotting or printing option is needed for publishing sheets in a single step.
