PUBLISHCOLLATE system variable
Collate published sheets
Combines published sheets with equal output configurations into single multi-page plot job.
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Process the sheet set in multiple steps (one sheet at a time) to generate a PLT file for each sheet. When plotting, the sheet plotting sequence can be interrupted by other plot jobs.
On (1): Process the sheet set in one step to generate one multi-sheet PLT file. When plotting, the sheet plotting sequence cannot be interrupted by other plot jobs.
Note: A plot driver that supports the multi-sheet plotting or printing option is needed for publishing sheets in a single step.
