QUADDISPLAY system variable
Quad display
Specifies when to display the quad. When the value is 8: suppress the quad when hovering over entities that are not in the current selection set; set Show Quad on right-clickON to display the Quad. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
-15 to 15 |
| Default value: |
5 |
| Possible options: |
negative: Switch off quad 1: Display the quad when the cursor hovers on an entity 2: Display the quad when entities are selected 4: Display the quad on right click 8: Suppress the quad on hover when entities are selected |
