REDHILITEPARTIAL_SELECTEDEDGEGLOW_ALPHA system variable
Glow transparency
Controls the transparency of the glow. See also the REDHILITEPARTIAL_SELECTEDEDGE_SHOWGLOW system variable.
Values between 0 and 100 are accepted.
- A value of zero means fully transparent.
- A value of 100 is fully opaque.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 100 |
| Default value: |
75 |
