ROLLOVERTIPS system variable
Rollover tips
Toggles the display of entity properties in the Quad, on hover.
Note: When the SELECTIONPREVIEW system variable is Off, the ROLLOVERTIPS system variable is ignored, and entity properties are not displayed when you hover the cursor over entities.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t show properties on hover On (1): Show properties on hover |
