SECTIONOFFSETSTEP system variable
Section plane offset step
Step size used for increments of the section plane offset property.
When set to a negative value, BricsCAD® determines the step size automatically based on the section plane properties.
BricsCAD only
Type:
Real
Saved in:
Preference
Default value: -1
