SELECTIONMODES system variable
Selection modes
Controls what is selected by default: whole entities, subentities or boundaries.
Use the TAB key, on hover, to cycle through the options.
BricsCAD only
Type: | Short |
Saved in: |
Registry |
Range: |
0 to 15 |
Default value: |
0 |
Possible options: |
1: Select edges 2: Select faces 4: Select detected boundaries 8: Select vertices |
