SELECTIONPREVIEW system variable
Selection preview display
Controls the rules used to highlight entities when the pickbox cursor hovers over an entity.
Applies only if the QUADDISPLAY system variable is off.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible options: |
1: When no commands are active 2: When a command prompts for entity selection |
