SHORTCUTMENU system variable
Shortcut menus
Controls the status of the DEFAULT, EDIT and COMMAND (right-click) context menus.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 63 |
| Default value: |
11 |
| Possible options: |
0: Disable all shortcut menus (Default, Edit, and Command mode) 1: Display general commands when no entities are selected 2: Display contextual commands when entities are selected 4: Display command options when commands are in progress 8: Display command options when commands are in progress and command options are available 16: Display shortcut menus when the right mouse is held down 32: Repeat command with short right click when entities are selected and Quad is not shown |
