SELECTIONPREVIEW system variable
Selection preview display
Controls the rules used to highlight entities when the pickbox cursor hovers over an entity.
Note: When the SELECTIONPREVIEW system variable is Off:
- the Display the Quad when the cursor hovers over an entity option of the QUADDISPLAY system variable is ignored and the Quad is not displayed,
- the ROLLOVERTIPS system variable is ignored and entity properties are not displayed (the Quad is not displayed),
- the SELECTIONCYCLING system variable is ignored and no badge or selection dialog box is displayed (the Quad is not displayed).
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible options: |
0: Do not display selection preview. 1: When no commands are active 2: When a command prompts for entity selection |
