SHOWDOCTABS system variable
Document tabs
Toggles tabs on/off, in the documents tab.
Note: You can make the drawing area larger by hiding the document tabs from the user interface.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Do not make tabs visible. On (1): Make tabs visible. |
