SMCONVERTBENDCOAXIALTOLERANCEFACTOR system variable
Tolerance factor on bend geometry
Tolerance on geometry of a bend, relative to the outer radius.
Lower values reduce (false) bend recognition, default 2.0, recommended 0.25.
Values between 0.01 and 10.0 are accepted.
BricsCAD only
Type:
Real
Saved in:
Drawing
Range:
0.01 to 10
Default value:
2
