SPAUSEFACETRES system variable
Use FACETRES system variable
Use the FACETRES system variable in place of normal tolerances.
Note: Spa is short for Spatial, the maker of ACIS.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Related commands
  • MODELERPROPERTIES command
Related variables
  • FACETRES system variable
Octave
