STARTUP system variable
Startup
Controls the display of the Create New Drawing and Startup dialog boxes.
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 3 |
| Default value: |
3 |
| Possible values: |
0: Display the Select Template dialog box, or use a default drawing template file. See also the BASEFILE system variable 1: Display the Startup and the Create New Drawing dialog boxes 2: Display the Start page 3: Display the Start page (with the Ribbon preloaded but not displayed) |
