USENEWRIBBON system variable
Use the new Ribbon
Uses the new Ribbon.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Disable the new Ribbon On (1): Enable the new Ribbon, a restart may be required |
