USENEWSETTINGSDIALOG system variable
Use the new settings dialog
Enables the new settings dialog.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 1 |
| Possible values: |
Off (0): Do not use the new settings dialog On (1): Use the new settings dialog |
