VIEWUPDATEAUTO system variable
Automatically update drawing views
Turns on automatic updates to drawing views (in paper space) when the source model changes.
When turned off, the VIEWUPDATE command manually updates the drawing views created by VIEWBASE and VIEWSECTION commands. This only works in paper space.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | On |
| Possible values: |
Off (0): Don’t update drawing views automatically On (1): Update drawing views automatically |
