WORLDVIEW system variable
World view
Controls if the DVIEW or VPOINT commands change the current UCS to the WCS.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible options: |
0: UCS remains unchanged 1: UCS changes to the WCS for the duration of the command; the command input is relative to the current UCS |
