Drawing linear entities
Commands for drawing linear entities are:
| 3DPOL comando | Draws polylines with x,y,z coordinates. |
| ARCO comando | Draws arcs. |
| CONTORNO comando | Creates a polyline that forms a boundary around closed areas. |
| CIRCULO comando | Draws circles. |
| ARANDELA comando | Draws wide circles from polylines. |
| ELIPSE comando | Draws ellipses and elliptical arcs. |
| HELICE comando | Draws 2D spirals or a 3D helices. |
| LÍNEA comando | Draws line segments. |
| LINEAM comando | Draws multilines. |
| POL comando | Draws connected lines and arcs. |
| POLÍGONO comando | Draws regular polygons out of polylines. |
| RAYO comando | Draws semi-infinite lines. |
| RECTANG comando | Draws rectangles and squares. |
| NUBEREV comando | Draws revision clouds. |
| BOCETO comando | Draws sketched (freehand) lines. |
| SPLINE comando | Draws open and closed splines in 2D and 3D. |
| TRAZO comando | Draws wide line segments. |
| XLINEA comando | Draws infinite lines. |
