FILTERPANELCLOSE command
Closes the Filter panel.
Closes the Filter panel to hide it from the current workspace. If the Filter panel is stacked when you close it, the Filter tab or icon is removed from the stack.
Parent topic: Referencia de los comandos
Related commands
  • FILTERPANELOPEN command
  • SELECR comando
Related information
  • Personalización de la cinta
  • Panel de filtros
  • Paneles
  • La cinta
