Property Lookup Table dialog box
Opens via:
  • BACTION command
  • BACTIONTOOL command > Lookup option
  • BLOOKUPTABLE command
Aviso de exención de responsabilidad
Important: En caso de que adquiera BricsCAD en EE. UU. o para utilizarlo en EE. UU., la función para crear o editar definiciones de bloques dinámicos no está disponible ni cuenta con licencia para su uso. Consulte el EULA para obtener más información.
The Property Lookup Table dialog box edits the properties of the selected lookup action.
Add Properties ...
Opens the Add Parameter Properties dialog box to display the available parameters.
Select the parameters to be added as property columns.
Audit
Searches for errors in the Property Lookup Table.
Input Properties
Edits the values of the added parameters.
Lookup Properties
Adds names to the lookup table options.
Custom
Displays as a lookup table option when a value is inserted manually in the Properties panel for a parameter used in the lookup table.
Reverse lookup drop-down list
Read only
Deactivates the reverse lookup.
Allow reverse lookup
Activates the reverse lookup.
Right-click a column header to display the context menu options.
Sort
Sorts the rows in the table based on the values in the selected column, ascending or descending.
Delete property column
Deletes the selected parameter column.
Clear contents
Removes the cell contents of the selected column.
Right-click a cell to display the context menu options.
Insert row
Inserts a row above the selected one.
Delete row
Deletes the selected row.
Clear contents
Removes the content of the selected row.
Move up
Moves the row up a position.
Move down
Moves the row down a position.
