Settings dialog box (Experimental)
Disclaimer
The new Settings dialog box is an experimental feature that may not yet be stable and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
About
Opens via:
  • SETTINGS command
  • SETTINGSSEARCH command
Note: The new Settings dialog box opens only if the Experimental mode is enabled. Otherwise, the old Settings dialog box opens.
The Settings dialog box allows you to change the values of system variables and user preferences.
  1. Search bar
  2. Categories
  3. Detailed category settings
  4. Import
  5. Export
Search bar
Lists variables through a real-time search field when entering letters of their names or descriptions.
Categories
Lists the settings categories. The categories of settings available depend on the BricsCAD® license level.
Note: Some categories are not yet implemented.
Displays all subcategories of selected category settings and their detailed settings.
Display
Lists general settings related to display (user interface, color theme, Ribbon style, background, Quad & context menu, cursor, user coordinate system).
Advanced settings
Lists all settings.
Modified settings
Lists all settings whose values ​​are different from the default.
  1. Revert all settings to default
  2. Modified setting list
  3. Revert setting to default value
Reverts all setting to the default values.
Lists the modified setting and marks them with a blue bullet.
Reverts the setting to its default value.
Import
Opens the Import Settings Profile dialog box to import all settings and values from an ARG or REG file.
Export
Opens the Export Settings dialog box to save all settings and values to an ARG or REG file.
Note: Settings that are stored in the drawing will not be exported.
