Migrating custom drawing templates
Drawing templates are DWT files that stores settings specific to the drawing and project requirements, such as units, layers, styles, layouts, etc.
To migrate custom drawing templates, locate each file, copy and save it in the corresponding BricsCAD folder.
Migrating custom drawing templates from AutoCAD®
Go to AutoCAD® and launch the OPTIONS command. Click the Files tab, go to the Template Settings section to find the location of the drawing template file and copy the files.
Then, go to BricsCAD and launch the TEMPLATEFOLDER command to open the folder where the drawing template files are stored. Paste the files.
Migrating custom drawing templates from a previous BricsCAD version or a different computer
Go to the previous version of BricsCAD or to BricsCAD on a different computer. Launch the TEMPLATEFOLDER command to find the location of the drawing template file and copy the files.
Then, in the current version of BricsCAD launch the TEMPLATEFOLDER command to open the folder where the drawing template files are stored. Paste the files.
