Import Civil 3D dialog box
The Import Civil 3D dialog box allows you to create BricsCAD civil entities from an Autodesk® Civil 3D drawing.
- Select drawing to import
- Layer name template for Civil 3D objects
- Import native CAD objects
- Import Civil 3D labels as blocks
Specifies the drawing to import by clicking the Select button, which opens the Open File dialog box.
Edits the template that is used for the layer name of all Civil 3D objects.
Toggles the option to also import native CAD objects.
Toggles the option to import all Civil 3D labels as blocks.
