Pre-process point cloud data file(s) dialog box
The Pre-process Point Cloud Data File’s dialog box allows you to attach point cloud files (that were previously converted to BricsCAD's BPT format) to the current drawing.
- File Name
- Supported files
File Name
Specifies the name of the point cloud data file you want to attach.
Note: A manual search can be done in the window
above.
Supported files
Specifies the file types you will be able to choose from.
