AI_PYRAMID command
Creates a 3D polyface mesh in the shape of a pyramid.
Icon:
Creates a 3D polyface mesh in the shape of a pyramid with three or four sides. The sides of the base may have unequal lengths. Options allow you to specify a pointed, ridged, or flat top.
Methods
There is one method to begin creating a pyramid
- First point for the base of pyramid
Options within the command
- First point for base of pyramid
- Specifies the first point of the base of the pyramid.
- Second point
- Specifies the second point of the base of the pyramid.
- Third point
- Specifies the third point of the base of the pyramid.
- Tetrahedron
- Choose this option to finish creating the base of the pyramid after specifying the third point to create a three-sided pyramid (tetrahedron).
- Set apex of tetrahedron
- Specifies the top of the tetrahedron (1).
- Top surface
- Specifies the first point on top surface of tetrahedron, second point and last point of top surface.
- Set last point for base
- Specifies the fourth point of the base of the pyramid.
- Set apex of pyramid
- Specifies the location for the top of the pyramid.
- Ridge
- Specifies the start and end points to create an edge at the top of the pyramid.
- Top surface
- Specifies four points to create a face at the top of the pyramid.
