GCCONCENTRIC command
Creates a concentric geometric constraint on 2D entities.
Icon:
Creates a concentric constraint to ensure two circular or elliptical entities remain concentric.
Method to create a concentric constraint
This command has 1 method to begin creating a concentric constraint:
- Select first entity
- Begin creating a concentric constraint by selecting a circular or elliptical entity then:
- Select second entity
- Select a circular or elliptical entity to make concentric with the first entity. The first entity maintains its position while the second entity moves, as necessary, to become concentric.
