-OVERKILL command
Deletes duplicate and overlapping entities and combines duplicate blocks.
Deletes duplicate entities and overlapping lines, arcs, and polylines, and unifies partly overlapping or contiguous ones. Optionally moves duplicates to a dedicated layer.Combines duplicate blocks and optionally purges duplicate block definitions.
Options within the command
- Done
- Executes the overkill procedure.
- Ignore
- Sets the properties to ignore.
- None
- Properties are taken into account to determine if overlapping entities should be combined.
- All
- All properties are taken into account.
- Color, etc.
- The colors of overlapping entities are considered. If the colors match, then they are combined or deleted.
- TOlerance
- Sets the tolerance for the comparison process.
- optimize Plines
- Segments of selected polylines are evaluated individually, duplicate vertices and segments are removed. If lines or arcs duplicate a polyline segment, one of them is deleted, which might break a polyline.
- segment witDth
- Specifies if the width property of polyline segments is ignored.
- Break polyline
- Polyline segments are kept intact even if the duplicates are deleted.
- Yes
- Optimizes polyline entities.
- No
- Polyline entities are not optimized.
- combine parTial overlap
- Partially overlapping entities are unified into a single entity.
- combine Endtoend
- Collinear lines and polyline segments having coinciding endpoints are unified into a single entity or segment.
- Associativity
- Associative entities are not processed.
- delete or Move duplicates
- Determines what to do with duplicate entities.
- Move
- Entities are moved to Overkill Layer.
- Combine duplicate block definitions
- Searches the drawing for duplicate block definitions and replaces all such block instances by the most recent of these duplicates.
- Purge duplicate block definitions
- Deletes duplicate block definitions.
