REPORTPANELCLOSE command
Closes the Report panel.
Closes the Report panel to hide it from the current workspace. If the Report panel is stacked when you close it, the Report tab or icon is removed from the stack.
REPORTPANELCLOSE command - BricsCAD Lite & Pro | Centro Assistenza Bricsys
