-WBLOCK command
Saves blocks and other drawing entities to DWG/DXF files.
Saves blocks and other drawing entities through the Save Block dialog box.
Options within the command
- Block to save as WBlock
- Specifies name of the block to write to a file.
- Select entities
- Selects entities to write to the file on disk.
- Insertion point
- Specifies the origin point of the drawing.
- Select entities
- Specifies the entities to create a block.
- Annotative
- Saves the block as an annotative block.
- & to include multiple blocks
- Saves multiple blocks from this drawing to the file on disk.
- * for whole drawing
- Saves the whole drawing, equivalent to SaveAs.
