AREAUNITS system variable
Area units
Controls a list of units used to display areas, if area properties are formatted with the PROPUNITS system variable. If empty, all areas match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Registro di sistema |
Valore predefinito: | in ft mi µm mm cm m km |
