BACKZ system variable
Back clipping plane offset
Specifies the current viewport's back clipping plane offset from the target plane, expressed in drawing units. Clipping planes are used in the CLIPPING option of the DVIEW command.
| Type: | Real |
| Saved in: | Drawing |
| Default value: | 0.0 |
