BLOCKIFYMODE system variable
Blockify settings
Defines the behavior of the BLOCKIFY and PARAMETRICBLOCKIFY commands. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
16 to 247 |
| Default value: |
48 |
| Possible options: |
1: Use entire drawing as search space 2: Use default block insertion point 4: Use default block name 32: Compare geometry only 64: Convert unique solids to blocks 128: Show preview |
