COMMUNICATORBACKGROUNDMODE system variable
Perform import and export in background
Enables user interaction while import or export is performed.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Disables user interaction while import or export is performed. On (1): Enables user interaction while import or export is performed. |
