EXTRUDEINSIDE system variable
Extrude behavior inside
Controls how new entities, modify a parent entity when they intersect. Applies to entities as they are created with the EXTRUDE and REVOLVE commands, when the Auto option is selected.
A parent entity is any entity that touches the contour from which the extruded/revolved entity was created.
The EXTRUDEINSIDE system variable is one of the four system variables found under the Extrude mode group.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Area di Lavoro |
Gamma: |
0 to 2 |
Valore predefinito: |
0 - for Workspaces Drafting and Modeling 1 - for Workspaces Mechanical and BIM |
Possibili opzioni: |
0: Do not modify 1: Subtract created entity from parent 2: Unite created entity with parent |
