REVCLOUDMAXARCLENGTH system variable
Revision cloud default maximum arc length
Controls the default maximum arc length for revision clouds. The maximum arc length is multiplied by the value of the DIMSCALE system variable.
Tipo: |
Reale |
Salvato in: |
Registro di sistema |
Valore predefinito: |
0.375 |
