The LookFrom control
The LookFrom control is a visual navigation tool in BricsCAD® that allows you to switch between a number of preset view orientations, such as orthographic views and isometric views.
By default, the LookFrom control is displayed in the top right corner of the graphic screen.
Note: The behavior of the LookFrom control can be customized by several system variables and user preferences. See the Using the LookFrom control article for more information.
