Combine Duplicate Block Definitions dialog box
The Combine Duplicate Block Definitions dialog box allows you to search the drawing for duplicate block definitions and replace all such block instances by the most recent of these duplicates.
- Block definition entity properties to ignore
- Comparison tolerance
- Options
Specifies the block properties to ignore when searching for duplicate block definitions.
Sets the tolerance for overlapping blocks. If set to 0 (zero), entities must match completely before being evaluated in the overkill process.
Options
Purge duplicate block definitions
Deletes duplicate block definitions.
