3DOBRÓĆ polecenie
Obraca elementy wokół osi w przestrzeni 3D.
Opis
This command has the functionality of the ROTATE3D command.
See the ROTATE3D command article for more information about rotating 3D solids, surfaces, 2D entities, faces (planar, cylindrical, spherical, conical, and toroidal faces of a 3D solid or surface), edges, or vertices of a solid around an axis.
