-ADDSURFACELABELS command
Adds labels to a surface labels via Command line.
Creates spot elevation labels, slope labels or contour labels on a surface via the Command line.
Method
Select the label type (contour, spot elevation or slope), enter the label style name, enter the symbol style name, then select the TIN surface to add labels to.
Lastly, select the label position or select the grid option to create multiple labels at once.
Options within the command
Contour
Creates major and minor contour labels using the selected label styles.
spot Elevation
Creates spot elevation labels using the selected label and symbol style.
Grid
Places spots elevation on a grid with a specified origin, X and Y spacing, rotation and extents.
Slope
Creates slope labels using the selected label style.
Single point
Creates a slope label by indicating a point on a surface.
Two points
Creates a slope label by indicating two points.
