-ADDVERTICALALIGNMENTVIEWLABELS command
Adds labels to a vertical alignment view via Command line.
Adds station and elevation labels or depth labels to a vertical alignment view via the Command line.
Method
Select the label type (station elevation or depth), enter the label style name, then select the vertical alignment view to add labels to.
Options within the command
- Station
- Adds station elevation labels using the selected label style.
- Depth
- Adds depth labels using the selected label style.
