AMPOWERDIM_RAD command
Creates radial dimensions for arcs and circles as ACM entities.
Icon:
This command is a shortcut to the Radial Radius option of the PDIM command. It automatically adds a radius symbol to the dimension text.
Method
Select the arc or the circle and the location of the dimension line.
The Edit Dimensioning dialog box opens to define the parameters of the dimension.
Note: For more information about the dialog box, see the related article Edit Dimensioning dialog box.
Options within the command
- Angle
 - Sets the angle of the dimension text.
- Text
 - Overrides the dimension text.
