-BIMPROPAGATEFROMFILE command
Propagates a saved detail.
Propagates a saved detail on all suitable connections in your project.
Note: The prompt sequence depends on the selected detail type: planar, linear, patter, edge or corner.
Method
Specify the full path and file name of the saved detail.
You can accept or reject suggestions by clicking on the tick.
- A green check mark means that the suggestion will be applied.
 - A question mark means that the suggestion will not be applied due to one of several possible reasons.
 - A red X mark means that the suggestion will not be applied.
