FILEOPEN command
Opens files from the Command line.
![BricsCAD Shape; BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_INTL/command-reference-all.png)
Opens drawing (DWG), template (DWT), and interchange (DXF) files from the command line, replacing the current drawing.
Options within the command
- Save the changes to drawing file?
- Specifies whether the current drawing should be saved or not.
- Open Drawing
- Type the name of the drawing, including path.
