MATERIALVOLUMETABLE command
Generates a material volume table.
Icon:
Opens the Create Material Volume Table dialog box to generate a material volume table for an existing Section line group and Material list. This table can be inserted into the drawing and saved as a CSV file.
Section line group
Selects the section line group that define the section volume.
Material list
Selects the material list name.
Table layout
Defines the table layout.
Earthworks
When checked, includes the earthworks materials in the table.
Materials
When checked, includes the structural materials in the table.
Options
Defines how the table is used.
Insert in drawing
When checked, inserts the table in the drawing at the specified insertion point.
Save to file
When turned on, saves the table as a CSV file.
File name
Displays the file name. Click the Browse button () to open the Select CSV file dialog box, then choose the path and a file name for the CSV file.
