-PSETUPIN command
-PSETUPIN command
Imports page setup definitions.
Imports page setup definitions from another drawing through the Command line.
Note: Page setups define how a drawing is printed and are used by the Print and Publish commands.
Method
Run the command to open the Select Page Setup From File dialog box.
Parent topic: Opis poleceń
Related commands
  • PSETUPIN command
  • PAGESETUP command
  • PRINT command
  • Polecenie PUBLIKUJ
Related information
  • Standard open file dialog box
