PLOTTERMANAGER command
Create and edit plotter settings.
Opens a generic system dialog box PlotConfig where you can choose a plotter configuration file or where you can create and edit customized parameter PC3 files for printers and other output devices.
Parent topic: Opis poleceń
  • CONVERTCTB command
  • KONWERSJASTYLWYDRUKU polecenie
  • PAGESETUP command
  • Polecenie STYLWYDRUKU
  • PRINT command
  • KREŚL polecenie
  • STYLESMANAGER command
Related Information
  • Plotter configuration
