POINTCLOUDTOMESH command
Generates a mesh from a point cloud.
BricsCAD BIM
Icon:
The command generates a mesh based on the visible points of a point cloud with normals.
Method
Isolate the part of the point cloud you want to generate a mesh from. You can use classes, cropping or regions.
Launch the command to open the Point Cloud to Mesh command context panel.
Specify a mesh resolution and trim the mesh by adjusting the Clean up value. Optionally, specify the desired number of faces for the final mesh.
Note: You can inspect results more effectively by changing visual styles.
Click Finish to create the mesh as displayed in the preview and exit the command.
Click Cancel to exit the command without creating a mesh. This can take longer depending on how advanced the processing is.
Note: The options within the command context panel reflect the options within the Command line.
Options within the command context panel
Generate Mesh
Specifies the desired resolution of the constructed mesh. A higher resolution will result in a more detailed mesh, but will take more time to compute.
The options are Low, Medium, High and Very high.
Note: The Very high setting may take a log time to compute or may not succeed depending on the point cloud and available memory resources. This option is recommended only if lower resolutions do not produce satisfactory results.
Generate
Click to start the process and proceed.
The system displays a progress bar on the lower-right side of the screen.
Clean up
Removes faces that are poorly supported by point data and helps eliminate unwanted surfaces created when the algorithm closes gaps.
Adjust the low-density threshold to trim the mesh properly.
Use the slider to adjust the value or type the value in the field. A preview of the mesh displays in the model space after the value change.
Confirm
Click to confirm the value and proceed.
Simplify mesh
Simplifies the mesh to make it lighter to work with and to decrease the overall file size.
Specify the desired number of faces for the final mesh.
Note: You can also use the MESHSIMPLIFY command after the mesh is generated.
Hide point cloud during command
Displays only the preview of the mesh in the model space.
Color mesh
Colors the preview of the mesh in the model space to better distinguish it from the point cloud.
