RECTANG command
Creates a polyline in the shape of a rectangle.
                Icon:
Alias: REC, RECT, RECTANGLE
Creates a closed, four-sided rectangular polyline in the shape of a rectangle,
                square, and variants with chamfers or fillets.
                    - First corner
 - Second corner
 - Length
 - Width
Methods to create a rectangle
This command has 5 methods to begin creating a rectangle:
- Select first corner of rectangle
 - Rotated
 - Square
 - Area
 - Dimensions
Additional options: [Chamfer/Fillet/Elevation/Thickness/Width of line]
 - Begin creating a rectangle by specifying a corner of a rectangle then:
 - Other corner of rectangle:
 - Specify the opposite corner of the rectangle. The rectangle is drawn parallel to the x and y axes.
 - Rotated
 - Rotation angle for rectangle
 - Specify the rotation angle of the rectangle.
                                - Rotation angle
 - Square
 - Begin creating a rectangle by specifying a corner of a square then:
 - Second corner of square
 - Specify a corner along the same side of the square to define its length and angle.
 - Area
 - Begin creating a rectangle by specifying its area then:
 - Calculate rectangle dimensions based on [Length/Width]
 - Choose whether to use the length or width to
                            calculate the dimensions for the rectangle.
- Length: enter rectangle length
 - Width: enter rectangle width
 - Dimension
Begin creating a rectangle by specifying its length then:
 - Width to use for rectangles
 - Specify the width of the rectangle.
 - Specify the first corner of the rectangle.
Options within the RECTANG command
After you begin creating a rectangle, the following options may be available:
- Chamfer
 - Specify the first chamfer distance to use for all rectangles then:
 - Second chamfer distance to use for all rectangles
 - Specify the second chamfer distance to use for all
                        rectangles
                            - First chamfer distance
 - Fillet
 - Specify the fillet distance to use for all rectangles.
 - Elevation
 - Specify the height above the xy-plane to use for all rectangles.
 - Width of line
 - Specify the width of the rectangle line segments. All segments have the same width.
 - Thickness
 - Specify the thickness of the rectangle line segments. All segments have the same thickness.
 - Turn chamfer off
 - Turn off chamfer.
 - Turn fillet off.
 - Turn off fillet.
 - Use default
 - Reset the default value.
