Create Material List dialog box
Opens via: CALCULATESECTIONVOLUMES command
The Create Material List dialog box allows you to define the material name and to select the base surface and the comparison surface.
- Material list name
- Allows you to define a material name.
- Base surface
- Allows you to select the base surface from the drop-down list of the available surfaces, or select it directly from the drawing area.
- Comparison surface
- Allows you to select the comparison surface from the drop-down list of the available surfaces, or select it directly from the drawing area.
